Mudfish not working in dota2 perfect world server, wtfast and xunyou works fine.
Using it here in PH. Does Mudfish servers does’nt have access to mainland China?
Yes I tried it, it lowers ping around 95-120 but not like xunyou that can lower ping to around 40-70. Im currenty using PLDT DSL btw.
I’m not sure Which a mudfish node is best to connect the China game server? section is helpful for you. However frankly speaking I’m not sure how good Mudfish is for China mainland if you’re comparing xunyou because as you know its no. of nodes at Mudfish are small.
I’m using HK aliyun. It has some ping spikes and packetloss yet It’s still quite playable.
