Mudfish SOCKS only mode, without activating TAP-Adapter
Hi, could you add an option where Mudfish can be active without using TAP-Adapter? I will be using Proxifier to access Mudfish through SOCKS only, as I will be using the TAP-Adapter somewhere else for my private PC-wide VPN.
Extra: As an alternative, can I have an option to choose which TAP-Adapter Mudfish will be using? (It is possible to have multiple TAP-Adapter installed)
The relevant OpenVPN parameter is:
--dev-node “ADAPTER_NAME”
