請問只要開啟Mudfish  Twitch 就會轉圈圈轉不停
請問只要開啟Mudfish  Twitch 就會轉圈圈轉不停無法正常收看 如何改善?
對了不要叫我多付1美去設定twitch~
Sorry for answering in English because we’re not offering Chinese technical support.
However if I understand your question, it seems you have a problem to watch Twitch if you’re running Mudfish, right?  If then I’m not sure this could be fixed because if I know correctly, Twich is also located on Amazon EC2 though Overwatch game servers are on Amazon EC2.
Did you try to turn off (disable) Overwatch game item while watching Twitch?  I’m guessing that it could affect it.
일단 59 IP 대역에 대한 만리장성 방화벽의 차단은 풀린 상태입니다. ㅠ.ㅠ 이 부분은 걱정하지 않으셔도 됩니다.
아그리고 소마구 vps 는 서버를 끄면 요금이 나가는 건가요?
서버를 Power Off 하셔도 나갑니다. ㅠ.ㅠ 더 이상 과금 적용을 받기 싫으시다면 서버 자체를 삭제하셔야 합니다.
I tried the Full VPN Mode and it didn’t work. Can i have a refund please? I will stop playing overwatch since I tried every VPN available and they didn’t work. Thank you!
No problem. :slight_smile: I’d refunded it now. Thank you for interesting to Mudfish!
