My game is Blade and SOul and
My game is Blade and SOul and not in game list, how can i play it with mudfish
Thanks you, how i know my game is really connect with mudfish.
And Does fastconnect mode effect to other programs ?
Frankly speaking, it’s not easy topic to answer unless you’re using Full VPN mode because as default, mudfish only redirects some of IP ranges depending on game item.  If you’re using Full VPN mode, I can guarantee that it’ll be connected through mudfish node.  But if not, it might be yes but sometimes it could be no.  And please check How do I know if its working? too.
No.  It’s only affecting to connections through mudfish program.
You’re welcome.  Please let me know if there’s other issue.
답변 해주셔서 감사합니다.full vpn 사용으로 해놓고 사용한 문제네요.ㅠㅠ앞으론 유의해야겠네요 ㅠㅠ
Sorry for this belated response. :slight_smile: When I checked the packet dump you sent, did you enable Full VPN mode while you performed the packet dump? I can’t see any game related packets on it.
And could you test and play the game with Full VPN mode enabled? Is it working fine however?
Full VPN wasn’t turned on during the packet dump, as I use too much external traffic that it was draining my credits.
Now, for the past few weeks, the latest incarnation of pRO had its own set of problems with connectivity, so i’ll take another shot at Mudfish for any improvements.
If it still does not improve, expect another packet dump soon. Thank you.
It seems you’re referring to http://mudfish.net/forums/7/topics/27533 link. :slight_smile:
