My ping isn't reducing and not
My ping isn’t reducing and nothing is showing on my dashboard, as in the graph.
Please advise.
Weird… Did you solve your problem now?  If not please update it for me. :-)
Oh I see.  It looks like you encountered MUDEC_00045 error in the previous.  Please check this error document and see the workarounds if you’re using Windows 10.
Then it’s different if you’re using -I option because it doesn’t make the mudfish prompt for new network. :-)  However without -I option, it should prompt if it works properly.
