need help. I can not use the program. is there any tutorial? I play H1Z1
Our official document is available at http://mudfish.net/docs/ link. Please check and let me know if there’s a problem. :-) However I think you’re using correctly according to your configuration. I think you can try to use Full VPN mode if you feel it’s not applied properly.
