need help. Whenever i clicked
need help. Whenever i clicked on the mudfish launcher, this error msg will appear “No TAP-Win32 Driver found.” My OS is win10.  i tried to installed openvpn, the error msg will appear “Can’t install Tap”.  Anyone one know how to solve this problem.  Thanks.
Did you check TAP-Win32 adapter v9 link?  Normally it’s caused by corrupted registry of Windows.  Please google “OpenVPN TAP” driver and try to other solutions for OpenVPN because Mudfish uses a exact same driver used by OpenVPN.
Did you check c:\Windows\inf\setupapi.dev.log file before?  Normally it includes most detailed error messages regarding to your failure to install TAP-Win32 adapter v9.  Or please try to send it to support@loxch.com email address.  I can give you more suggestions depending on its error type.
