Please help my tap32 adapter is not working with this account but it is working with my brother’s account. I have 24.23GB left in this account.
It only works when i try to logout and relogin for like 10 times. but it works fine with 1 login in my brother’s account.
Are you using -t option for Mudfish Launcher mentioned at Firewall Issues link? If not please try to use it whether there’s a different.
Or are you using any kind of TCP optimizer tools? It seems that there’s an issue to fetch the routing table information from mudfish master server for your account. If you delete current item equipped, it could make different.
