Since a few weeks every node seems to be instable. It keeps disconnetcting me from the game - doesn’t matter which node i pick.
Shall i use a node with low RTT? I don’t know what else i can do :(
Did you try to test with following options?
Turn off FastConnect mode.
Change Connection Protocols from UDP to TCP
No problem.
I’d changed your data plan to PPT (Pay Per Traffic) and reset your changable date too. If you’d like to change it back I think you can do again.
