Since couple weeks ago, my gam
Since couple weeks ago, my game would turning to lag-spakes from 1-2 seconds. I pretty sure nothing wrong with my internet/router because i have been check with other pc and games. Before my ping would stay around 220-223 without a single spike, but now it keep going every now and then…
Please check your ISP first. When I checked RTT information recorded in Mudfish, it seems RTT stddev values to most of the mudfish nodes are quite unstable. It means your ISP has a network issue. For details please check http://ko.loxch.com/userrtt/?uid=285594 link.
I did call up my isp, they say there are no problems or reason why it’s lagging. even check the speed test, it’s quite stable on their system? what should i do ?
If you tried to check the speed test, normally it’s being performed at your local ISP or country side. My point was that it seems there’s a problem at the international side though I guess your ISP engineer isn’t familiar with this similar issue.
For this case, I think you should check ‘Status -> Nodes’ menu and see RTT stddev values carefully because it points it’s stability of your connection to mudfish nodes. Please pick and use stable node if possible.
