So I've noticed with Titanfall
So I’ve noticed with Titanfall 2, playing from Taiwan I’ll sometimes be put on a Japanese server, and sometimes be put on the Hong Kong server.  I can’t tell for sure if mudfish is working properly when it isn’t set to the right location.  Are the server locations in item set up just to calculate RTT, or does it actually effect the routing?
If it does effect routing, is there anyway I could have mudfish grabbing traffic for both locations at once other than using full VPN mode?
Thanks.
