[STDOUT]
[0.005000] [INFO] mudfish v4.4.5 (for x86_64)
[0.006000] [INFO] Timestamp: Mon Oct 23 23:13:48 2017
[0.007000] [INFO] Full VPN mode is enabled
[0.007000] [INFO] Connection protocol: udp
[0.007000] [INFO] Authenticating…
[0.063004] [INFO] Fetching the static nodes…
[0.432025] [INFO] Fetched 317 static nodes from the master.
[0.451026] [INFO] TAP-Win32 Driver GUID {5847ACD5-1DAF-4069-AB5C-95DF1B5FFC7C}
[0.451026] [INFO] TAP-Win32 Driver Version 9.9
[0.452026] [INFO] TAP-Win32 Driver MTU 1500
[0.452026] [INFO] Setting TAP-Win32 Adapter v9’s MTU to 1450
Ȯ�ε�
[0.631036] [INFO] TAP-Win32 Driver TcpNoDelay diabled
[0.631036] [INFO] TAP-Win32 Driver TcpAckFrequency 1
[0.631036] [INFO] TAP-Win32 Driver TCPNoDelay 1
[0.655037] [ERROR] MUDEC_00196: SID 9 ((null)) isn’t alive.
[0.656038] [INFO] Setting the default gateway as 10.255.32.1 (9 (null))
[0.656038] [ERROR] MUDEC_00309: Failed to write the routing socket message: 51 Network is unreachable
[0.658038] [INFO] Ready
[0.750043] [INFO] Listening the management console at 127.0.0.1:49774
[1.657095] [INFO] Waiting until the client’s ready to handle the routing path list.
[4.656827] [INFO] Waiting until the client’s ready to handle the routing path list.
[5.027848] [INFO] DHCP request for 00:ff:58:47:ac:d5 (������-PC) from interface
[5.043849] [INFO] DHCP discover for 00:ff:58:47:ac:d5 (������-PC) from interface
[5.043849] [INFO] DNS address: 8.8.4.4
[5.044849] [INFO] DHCP request for 00:ff:58:47:ac:d5 (������-PC) from interface
[5.044849] [INFO] DNS address: 8.8.4.4
[5.044849] [INFO] DHCP Client got IPv4 address now
[7.656999] [INFO] MFP 0 FlowMTU - 14.63.214.216 1500
[93.770924] [INFO] MFP 0 RouteAdd - 120.26.1.0 255.255.255.0 76 76 0 n
[93.770924] [INFO] Fetching new static node SID 76…
[93.788925] [INFO] re35: Associating with ip 182.162.90.209 port 10008
[93.789925] [INFO] re35: Connected to 182.162.90.209:10008 (UDP)
[93.789925] [INFO] MFP 0 RouteAdd - 64.124.47.0 255.255.255.0 76 76 0 n
[STDERR]
Empty file.
