Sudden high usage
Was playing maple with nothing else on, but 10mins shown usage of 2GB
checking connection shows that 2gb was used by mudfish
Only happens with fastconnect mode
:frowning: Weird… If I checked your configuration, it seems you enabled Full VPN mode. For this case, please check the link because it includes more details. If it’s enabled, your all network traffics will be redirected via the mudfish node you set. So this could consume a lot of traffics if you didn’t use it carefully.
For your convenience, I reset your mudfish credits a little bit.
