VPN connection issue
Hi,
I am contacting you regarding an issue with VPN routing while playing MapleStory. The in-game connection speed felt as if the VPN was not applied at all (experiencing high latency/no speed improvement). Could you please check if the MapleStory item routing is working properly or if my traffic is bypassing the VPN node?
There was a no problem with system load, traffics, packet loss and scores.
this node was the best out of all the options when I picked.
Game: MapleStory
Node used: google 3 korea
Best regards
Levi
Hi! High ping alone doesn’t confirm VPN bypass. Your item targets South Korea—is that your MapleStory region? Please compare item-only mode with Full VPN using the same Korea Google 3 node. Restart Mudfish and the game after switching. Disable Full VPN afterward; it routes all traffic. If only Full VPN helps, the item’s coverage needs checking. Please share your OS, game region, ping with VPN off/item-only/Full VPN, and submit Support → Problem Report while the issue occurs.
I guess it was just a little technical issue back then. now it’s working all good, thanks.
You’re welcome! I’m glad MapleStory is working well again. Thanks for the update. If the issue returns, please reply here and we’ll be happy to help.
