WoW Pserver Warmane issues
Hi, I’m not having a good experience using Mudfish to play on the Warmane wow pserver. Without Mudfish, my latency is around 188–200 ms, but with Mudfish active, that number doesn’t drop significantly (it stays on 180-200 range). I thought it might be an issue specific to the Linux client of Mudfish, but I tested it on another computer running Windows and got the same result.
It’s been a frustrating experience; I use Mudfish because it supports Linux, but I have to switch to my Windows partition and use ExitLag to play with ~110–125 ms latency (and got a much more stable experience without lag spikes).
I tried optimizing and adjusting the settings, but nothing worked.
Sorry for the poor experience. Your Paris route measures ~190 ms, matching the game, and other Basic Mode routes to France are similar. This points to routing rather than Linux.
Open the WoW item → Setup → Nodes → Advanced Mode, click the magnifier, then choose the lowest-score route with a flat RTT graph—try a first node near you (Fortaleza/São Paulo) and a second near Warmane (Paris). Save and restart Mudfish and WoW. If still above 180 ms, send a Problem Report while connected.
