1)你遇到了什么问题?I am using mudfish
1)你遇到了什么问题?
I am using mudfish to connect to "black desert online japan" from Hong Kong every day. Everything used to be fine.However, it happened since 8-Sep 19:00 GMT+8, the connection seems slow that the response from the game is slow. I can still login the game but the response is very slow that I cannot play the game normally.. I have tried to connect to the game through different mudfish server but it seems to be the same. I tried to use the SoftEther VPN Client to connect to the game and everything is fine. but I do not want every connection from my computer to be connected through VPN so I prefer to use mudfish. Please help to review and solve the problem
2)遇到的问题可以怎样重现?
just connect to the game via mudfish client, connection is slow no matter which mudfish server I used
Download the report
Sorry for this inconvenience. However we need to check where this issue is from first. Did you see any ping (RTT) difference before and after? Or did you try to change Connection Protocols too?
