1) What's your issue encounter
  1. What’s your issue encountering?
[1.035252] [ERROR] MUDEC_00122: minidump path: C:\Users\MCHAM\AppData\Local\Temp\mud3F8C.tmp
[STDERR]
Empty file.
Only mudflow and muudrun is running
  1. How could it be reproducible?
Run the program in admin and go into status > process
Download the report
Ooop… This means ‘mudfish’ process is crashed… :frowning: Please try to do as follows:
  1. At https://mudfish.net/releases/ link, you can find old releases. So you can try to use the old one as a workaround.
  2. Or try to turn off FastConnect mode, then try it again though I’m not sure it’s helpful. :frowning:
This is what I ran the .tmp file at
http://www.osronline.com/page.cfm?name=Analyze
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 7 Version 7600 MP (4 procs) Free x86 compatible
Product: WinNt, suite: SingleUserTS
kernel32.dll version: 10.0.15063.246 (WinBuild.160101.0800)
Machine Name:
Debug session time: Sun Oct 29 11:49:37.000 2017 (UTC - 4:00)
System Uptime: not available
Process Uptime: 0 days 0:00:01.000
  Kernel time: 0 days 0:00:00.000
  User time: 0 days 0:00:00.000
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\oca.ini, error 2
TRIAGER: Could not open triage file : e:\dump_analysis\program\winxp\triage.ini, error 2
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\user.ini, error 2
*                        Exception Analysis                                   *
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\guids.ini, error 2
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
GetUrlPageData2 (WinHttp) failed: 12029.
FAULTING_IP:
IPHLPAPI!GetAdapterIndex+0
73c7e210 2a8b490c8d20    sub     cl,byte ptr [ebx+208D0C49h]
EXCEPTION_RECORD:  ffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 73c7e210 (IPHLPAPI!GetAdapterIndex)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000000
   Parameter[1]: 23844c61
Attempt to read from address 23844c61
DEFAULT_BUCKET_ID:  INVALID_POINTER_READ
PROCESS_NAME:  mudfish.exe
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
EXCEPTION_PARAMETER1:  00000000
EXCEPTION_PARAMETER2:  23844c61
READ_ADDRESS:  23844c61
FOLLOWUP_IP:
FAULTING_THREAD:  0000133c
PRIMARY_PROBLEM_CLASS:  INVALID_POINTER_READ
BUGCHECK_STR:  APPLICATION_FAULT_INVALID_POINTER_READ
LAST_CONTROL_TRANSFER:  from 00daffe4 to 73c7e210
STACK_TEXT:
004ff784 00daffe4 004ffbd0 00e5ce48 00000000 IPHLPAPI!GetAdapterIndex
WARNING: Stack unwind information not available. Following frames may be wrong.
004ffdd4 00db40db 00000000 00000000 00000000 mudfish+0x5ffe4
004ffe94 00e17eca 0000000e 029a1840 029a18f8 mudfish+0x640db
004ffedc 74938744 00354000 74938720 5e440b31 mudfish+0xc7eca
004ffef0 77e9582d 00354000 4547c15e 00000000 kernel32!BaseThreadInitThunk+0x24
004fff38 77e957fd ffffffff 77eb638c 00000000 ntdll!__RtlUserThreadStart+0x2f
004fff48 00000000 00e17f20 00354000 00000000 ntdll!_RtlUserThreadStart+0x1b
STACK_COMMAND:  ~0s; .ecxr ; kb
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  IPHLPAPI!GetAdapterIndex+0
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: IPHLPAPI
IMAGE_NAME:  IPHLPAPI.DLL
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  INVALID_POINTER_READ_c0000005_IPHLPAPI.DLL!GetAdapterIndex
BUCKET_ID:  APPLICATION_FAULT_INVALID_POINTER_READ_IPHLPAPI!GetAdapterIndex+0
WATSON_STAGEONE_URL:  http://watson.microsoft.com/StageOne/mudfish_exe/0_4_4_6/59ccf0dd/IPHLPAPI_DLL/6_2_15063_0/9fef3683/c0000005/0001e210.htm?Retriage=1
F
Yes I already checked my network devices. It is there. I already tried install Tap-windows from open VPN as well. Still the same issue.I will try reinstall windows 10 if that may help.
Not sure why with current information. However if you have another desktop or PC, please check it’s also happening at that machine. :frowning: I’ll try to look the code too.
처리해 드렸습니다. :-) 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
  • Run as administrator then wait for about 10 seconds to 5 minutes
I always run it as administrator. Followed your instruction and wait for more than 10 minutes, still didn't see the "+" button. Cannot post a screenshot here to show the page to you.
처리해 드린 것으로 보입니다. :-) 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
Did you enable Expert Mode? "+" button requires to enable it.
