2X Ping when using any Mudfish Node
Hello Team,
I am from the Philippines and I am trying to connect to Valorant (Hong Kong). Without Mudfish, I get around 19ms, but when I use Mudfish, I tend to get around 40ms. I’ve been using Mudfish for a very long time and I’ve been getting 21-23ms with Mudfish before. I tried to select a node originating from my country, but the ping is still 40-50ms. Any idea what changed or happened?
Thank you!
Hello weongyo,
Apologies for the late response, and yes it still is the same with Full VPN Mode. Though, I did have a change of ISP, could it be that my new ISPs route is trash? I expect Mudfish can be the solution to that, right?
:frowning: Not good if it’s still same with Full VPN mode enabled. Which mudfish nodes did you pick and test? If possible, please try to change other mudfish nodes and test because I guess that its result could be different depending on the mudfish nodes.
Not sure for this question. If possible, please send me some game packets using Packet Capture with Mudfish link while playing the game with Full VPN mode.
I need some game packets to analyze.
