4.5.5 is much better than 4.6.0 for Aura Kingdom idk why but 4.6.0 gave me more lags
- Please download and install latest Mudfish at https://mudfish.net/download
I did but the latest version made my AK laggier than usual, i went back to the earlier version and ping is stable on 220-250ms only
4.6.0 gave me spikes from 300-3000 ping which is ridiculous
- Do you running on Mac Operating System? https://github.com/Homebrew/homebrew/issues/31153
- Please check if you have modified registry like Latency Fix / FastPing / Hamachi or failed to install Mudfish
- change your node
https://mudfish.net/forums/6/topics/44662
Connection Protocol in TCPs
https://mudfish.net/forums/6/topics/37597
- run Mudfish with option lowercase `-s`
then access to https://ui.mudfish.net:8282
- China https://mudfish.net/forums/6/topics/44662 https://mudfish.net/forums/6/topics/37597
First Im not using MAC im on Windows 1903(OSBUILD: 18362.239)
2nd I dont have those 3 installed at all
3rd already kept changing nodes from 4.6.0 last time nonstop and all are giving me spikes from 300-3000 unlike 4.5.5 which SG OneProvider is steady at 200-250ms
4th as i said im not a MAC address user
5th im not doing those things since i dont want to mess my pc, and ill stay with 4.5.5 since its not messing up with my ping
- Please leave what you want to play alone then close other programs.
- Picking a node that shows near flat graph may considered more consistency.
- In general, network congestion has getting increased on night to early morning.
How to pick the best mudfish node for game I play?
- You can inspect how network traffic goes on with tools like WinMTR or PingPlotter.
- Release Notes
- MAC address means media access control address
ill try 4.6.1 if it works better but if its still giving me 300 and above ping then ill go back wiith 4.5.5
