Hello, I seem to have changed some settings from what I usually used at some point that I do not recall. Is there a way to simply reset all Mudfish settings to default? Default seems to have given higher performance than what I currently am using, and I do not remember which settings I need to change.
To reset your configuration, you can do as follows:
- Clicks ‘Reset’ button which found under ‘Setup → Program’ menu. This will reset the program configuration.
- Remove all items you’re using and equip it again. It’ll reset your item configuration.
