I checked other posts about this, but couldn’t find a clear answer for it. Is split tunneling possible with Full VPN mode ON? (Cuz I need it for some apps not all)
If so, how can I configure it?
@markins I’m not sure that I understand the feature ‘split tunneling’. Is it the same with the following situation?
If then I think you’re looking for Full VPN mode + WFP Item mode combination. I guess you can try as follows:
P:<processname> syntax. For example, you can add the exceptional rule for Google Chrome browser with P:chrome.exe.Hi, I didn’t see where I can setup the exception rule.
Under the Full VPN menu I can only turn on the WFP mode, but didn’t have any section I can input my own rules.
Could you give me a more specific instruction about how to setup the WFP item mode?
