suddenly from yesterday (2019-10-28) in China, we could not connect to Mudflish by iPhone, could you please hlep to check whether it’s blocked or just temp down or whatever, please try to fix,okay, really can’t no VPN to see the world what happended in everyday in China. many thanks guys
Please try to check if Mudfish working properly at https://myip.mudfish.net
hi you see it does not work, could you guys help to fix this issue, as it’s so hard feeling no VPN connection in china. thanks alot
well noted but i used iOS app for Mudfish to make connection, how to fix this issue? please help to advise. thanks a lot
Hi, i have added the items for Subscription plan, you see i still can’t connect Mudfish thru iPhone (iOS 13.1.2) thank you.
Umm… When I checked your screenshot, “Connection” indicates “Connecting…”. It means it try to connect but not connected yet. Is there any error / warning messages after this?
hi, suddenly yesterday it’s back to normal. thank you guys
