After using mudfish,my fortnite games have 200 ping in some games.And sometimes 40ping. Whats going on? I am sure the point is very fine
- Please check basic functionality
Please check where the program is in
C:\Program Files (x86)\Mudfish Cloud VPN\or not and are mudfish.exe / mudflow.exe into the path then
execute Mudfish VPN Launcher at Start Menu than any shortcut what you’ve
created. -
Then download a driver in 32-bit or 64-bit for your system
static.loxch.com/tools/tap0901-i386.zip
(32 bit)
static.loxch.com/tools/tap0901-x86_64.zip
(64 bit)
Extract it then run remove.bat
Run install.bat
