Always problem during diagnoes JP asia and KR Asia never load https://i.imgur.com/l0bcVYz.png
What about other nodes?
I did try diffrent nodes but it’s always the same effect I get past the login screen then it starts being extremely laggy towards the character screen
Here’s a Video to the Issue https://youtu.be/MKzH5MUK1D0
Thank you for sending this video! I’d checked your symptom but it seems it looks the auto configuration step doesn’t be completed properly because it stops at 50%. Please check the following things:
Please pick the mudfish node manually rather than auto selection option. At this moment I don’t recommend to use the advanced node mode.
Please try to change Connection Protocols to TCP based because sometimes MTU causes this issue.
I think changing to TCP has fixed it, thank you
Cool!
I hope now everything goes well with mudfish. Please let me know if there are any other problems.
