Hi guys, I am playing Valorant Singapore Sever in Melbourne (OCE). Currently in basic mode I have ping at 95ms. Is there any other way to lower the ping a bit more? Like adjusting the settings in mudfish and my modem. Mtu size, DMZ or something like those. Many thanks.
Did you try to see what the lowest ping is between Melbourne and Singapore on MUDFISH: Ping
I play on League of legends Singapore from south Africa and the best nodes in Singapore is
SG Asia (Singapore - DigitalOcean)
SG Asia (Singapore - OneProvider 2)
SG Asia (Singapore - OneProvider 3)
SG Asia (Singapore - OneProvider)
SG Asia (Singapore - OVH)
Those are the lowest servers in Melbourne to the Singapore nodes. So you can try Advanced mode and on the 1st node select a Melbourne node that is closest to you or gives you the lowest ping and then select a singapore node I listed above and see if you can get lower latency.
For this method,
The RTT from my pc to lowest servers in Melbourne is around 10ms.
Then Melbourne to singapore is around 80ms.
So the total ends up of 93ms.
is this already the most optimal situation theoretically?
Maybe try the Singapore servers directly to see if your ISP has the best routing then it looks like that is the lowest you can get based on distance.
