anyone can help me?  cant pl
anyone can help me?
cant play smoothly using mudfish now on black desert online, open process on mudfish and  got this :
[49.917516] [INFO] MUDEC_00037: Failed to do CONNECT to 103.10.124.14:80 (ver 5 rcode 1) [49.918020] [INFO] MUDEC_00038: TCP relay from the client (10.254.91.122:51175) to the backend (10.247.112.1:8081) failed. [90.435160] [INFO] MUDEC_00037: Failed to do CONNECT to 182.79.231.18:80 (ver 5 rcode 1) [90.435160] [INFO] MUDEC_00038: TCP relay from the client (10.254.91.122:51188) to the backend (10.247.112.1:8081) failed. [223.960665] [INFO] re0: Associating with ip 52.8.135.54 port 10008 [223.961161] [INFO] re0: Connected to 52.8.135.54:10008 (UDP) [223.961657] [INFO] Changed the default route to SID 3 [303.578858] [INFO] MUDEC_00037: Failed to do CONNECT to 209.58.135.134:6070 (ver 5 rcode 1) [303.578858] [INFO] MUDEC_00038: TCP relay from the client (10.254.91.122:51292) to the backend (10.255.32.1:8081) failed. [373.171767] [INFO] MUDEC_00037: Failed to do CONNECT to 211.253.9.30:80 (ver 5 rcode 1) [373.171767] [INFO] MUDEC_00038: TCP relay from the client (10.254.91.122:51351) to the backend (10.255.32.1:8081) failed. [384.917579] [INFO] MUDEC_00037: Failed to do CONNECT to 211.253.9.30:80 (ver 5 rcode 1) [384.917579] [INFO] MUDEC_00038: TCP relay from the client (10.254.91.122:51361) to the backend (10.255.32.1:8081) failed. [397.675460] [INFO] MUDEC_00037: Failed to do CONNECT to 211.253.9.30:80 (ver 5 rcode 1) [397.675460] [INFO] MUDEC_00038: TCP relay from the client (10.254.91.122:51369) to the backend (10.255.32.1:8081) failed. [404.840365] [INFO] MUDEC_00037: Failed to do CONNECT to 211.253.9.30:80 (ver 5 rcode 1) [404.840365] [INFO] MUDEC_00038: TCP relay from the client (10.254.91.122:51376) to the backend (10.255.32.1:8081) failed. [416.563185] [INFO] MUDEC_00037: Failed to do CONNECT to 211.253.9.30:80 (ver 5 rcode 1)&nb
