Anyone using Mudfish for The D
Anyone using Mudfish for The Division?
Which node should I pick playing from Vietnam?
Tried some JP node but the ping is spiking bad.
The game keeps throwing me to US server from Vietnam even tho there are servers in JP nearby. :(
Umm… Did you try to use Full VPN mode for this case?
Not yet, not even sure what node should I be picking.
If then please check FAQ - Nodes how to pick a better node.  However if you’re playing P2P based game, I think a node closer to your location is better to use.
문제점 보고서를 보내주셔서 정말 감사합니다. :slight_smile: 혹시 미꾸라지를 사용하시는데 문제가 있으신지요? 그렇다면 조금만 부연해 주시면 제가 좀 더 도움을 드릴 수 있을 듯 합니다.
혹시 다시 한번 확인해 보시겠어요?
First sorry for this incovenience. Unfortunately I think your issue is related with Amazon EC2, Twitch and Mudfish and CDN and Mudfish links. Please read these documents. However I’d reset your mudfish credits little bit.
Hello @loxch. I have read both links from your reply to avoid all possible problems in the near future, thank you so much for your reliable support, reply and understanding.
No problem! :slight_smile: I hope now everything goes well with mudfish. Please let me know if there are any other problems.
