Apex legends Game item issues + Usage issue
Alright so a couple issues here.
  1. The game item has server name that doesnt correspond to the way it is in the game.
    For instance Singapore in the game item is listed as ap southwest in the game and so on and so forth.
  2. the data usage has doubled since the changes or more then that (3x maybe), the change i am referring to is the recent apex legends server change that also caused the first issue.
  3. Also the ping isnt equal to one that the server finder suggests.
    for eg earlier if it said that it had 68 ping, it will have 68 ping when i connected.
    Now if its showing 68, its like 80 or more.
Kindly look into it, please.
Cheers.
Thank you for your feedback.
If possible, could you please show me a screenshot for the game server list in the game client? I need to update the game item.
If I know correctly, the game server moves to Amazon AWS. It means that now there’s a chance to encounter Amazon EC2, Twitch and Mudfish issue unfortunately. :frowning: So I guess that this could affect to your traffic usage.
When I get a chance, I’ll try to play the game and check this ping difference. Thank you for this report.
The thing is that i dont use twitch and so this shouldnt affect the usage right?
also its using even tho its completely idle.
If you don’t use Twitch, there’s another chance you can encounter CDN and Mudfish issue too because Amazon AWS operates the CDN service (aka CloudFront)…
