Hi i am using mudfish multi path mode on Singapore servers when it connect on mudfish dashboard its shows around 80 ms but when i enter in game on apex legends server selection it also shows 80ms but when i enter in firing range or any other mode its goes around 100ms+ what should i do?
Yes I Do But Nothing Changes
Which a mudfish node did you try? If it’s even same with Full VPN mode enabled, it’s weird… Please try to change a mudfish node to another and test.
If it’s even same, please check Packet Capture with Mudfish and send me some game packets.
i use every possible mudfish node and also use auto selection mudfish node but nothing can work.
i can send u game packets soon
