Auto configuration is stuck at 54%.Please help. Thank you very much
- Run as administrator then wait for about 10 seconds to 5 minutes
- run `netsh winsock reset` as administrator https://support.microsoft.com/en-us/help/299357/how-to-reset-tcp-ip-by-using-the-netshell-utility
- run Mudfish with option lowercase `-s`
then access to https://ui.mudfish.net:8282
- China https://mudfish.net/forums/6/topics/44662 https://mudfish.net/forums/6/topics/37597
