help please
it’s been running for 8 hours
Could you please send me Problem Report while this issue is happening? I need to check the internal logs.
And did you check ‘Status → Process’ menu to see “Core” log section? Please check if there’s an error or warning message there.
Weongyo, I don’t know what you did in the background but it looks like it fixed the problem! Thank you so much for your help. I really appreciate it
