Auto Connect in Linux?
If i remember correctly, I used to be able to do this on Windows, is it possible to auto connect in Linux too?
Im talking about this button, not auto login
Did you try to check “Setup → Program → Launcher” menu and try “Auto Connect” option? I think that it’s what you’re looking for.
Oh im so sorry, i thought auto connect in Windows was using the arguments in the Properties tab
Thank you so much
