https://gyazo.com/06c598c7c4c776f903e5c3cc24f6eadb
Reinstalled multiple times, restarted pc, closed via task manager and tried opening again. Nothing works. Also tried to log out. Was working perfectly a few hours ago. Cant use it now
Saw someone else say the same thing. You replied with
Im using 5.2.2
Google chrome and i am a user of windows.(doesnt work on other browsers anyways)
Even tried to start from scratch with everything, deactivated account and added funds. still doesn’t work.
So i tried to use a new chrome user for new cookies and no saved passwords and it turned out it worked. see how long this lasts…
Are you using KIS (Kaspersky Internet Security) product on your desktop? If then please check Debugging issue for Mudfish v5 link to solve this issue.
Am not using KIS
Weird… Then did you check “JavaScript Console” menu of the browser whether there’s a warning or error?
