Hello, my use case is a game server in Karachi (PK). I use mudfish since years, but usually I use it manually. Since this host has weird routing, i decided to use the Auto path (basic) but it is taking forever. It is currently at 1700 nodes checked in 6 hours+. I let it run because I thought it would just ping from <700 servers.
The destination server is the same ipv4 as the game host server.
Under item config I have checked:
Flow controller log:
Tue, 10 Sep 2024 15:53:40 GMT [957.354337] rttd [INFO] MUDEC_00774: UDP: select timeout for 103.27.184.118:10007
Tue, 10 Sep 2024 21:17:44 GMT [20401.253758] rttd [INFO] MUDEC_00774: UDP: select timeout for 37.252.1.97:10007
However I don’t suspect this is the problem because my ISP has a packet loss issue about every 30 seconds.
What’s going on? Is this normal behavior? Did I config wrong?
