Good morning, I would like to know what is the best configuration to play WoW from Chile.
Currently my ISP is VTR and I play between 170-200 ms, I tried Mudfish and the latency dropped to 150 ms with full VPN, since the option with acceleration made the game freeze every time.
I have a 940 mb link.
Regards
No perfect answer for this question because it’s very vary depending on which ISP you’re using or how is the international cable condition good. Please check FAQ - Nodes document first and test with various combinations.
Did you try to change Connection Protocols to TCP based? Sometimes changing the connection protocol could be helpful.
Thank you very much for your reply. I will do TCP and let you know how it goes.
Regards
