Best way to use with mobile
So I’m flaying FFXIV with the mudfish app and using hotspot to play. I haven’t noticed a difference really, I’m connected to a Japanese server in FFXIV. How do I run it optimally? Connect the vpn to the lowest ping server on the app and just play as normal?
Not sure that Final Fantasy XIV - A Realm Reborn link is helpful for you but please check.
However if you’re using with the hotspot via mobile, please make sure that your connection is stable to your ISP. I think you can test with WinMTR to know this.
