Every Mumbai Server in UAE is not working and high ping 200ms 600ms, previously only 40ms
Tried multi path and node setup in item. Deleted Item and tested. Still same.
Everything was working fine 1 week ago.
Did you try to test with "IN Asia (Mumbai - Amazon Lightsail X) mudfish nodes? Its public IP are changed to another yesterday. However if it’s even same, I think that BGMI blocks a connection from the cloud computing providers such as Amazon, Google, Microsoft and etc…
So you might need to use other mudfish nodes unfortunately.
Thanks @weongyo You are correct, this is BGMI blocking connections. Same happens on other VPN providers too.
