BNS NEO Tw is not working.
Unable to enter the game via any node.
For that case, I need to collect some game packets using Packet Capture with Mudfish.
Hi,
I have tried Full VPN mode as well as other modes, but I still cannot enter the game. Additionally, none of the TW/Asia nodes or routes are working for me.
Please let me know what the next steps are or how I can help with the packet capture.
Hi, thanks for testing.
First, please check if Mudfish works properly by following this guide: How to check the basic functionality.
If the test succeeds, Mudfish is applied properly. However, if this test works but you still can’t connect to the game with Full VPN mode enabled, it means the game server has blocked the Mudfish nodes.
In this case, please try connecting through different TW nodes to see if there is one that isn’t blocked. Let me know if you need further help!
