hi!
are you going to support Call of Duty: Warzone 2.0 Europe server?
hi!
ok,
sent you couple of dumps.
first one failed to upload through mudfish, so i sent it by email,
second one should be in * Packet Dump Topic
hello my friend !
and Call of Duty: Warzone 2.0 South América server, please?
@fchud It should be updated now. Please test when you get a chance.
@SapoNauta Please check above comment and send us some game packets. We need it to analyze.
thanx.
it kinda works, but i am not seeing any latency decrease.
and constantly having lag spikes to 999ms, every few seconds. (same happened when i was capturing packets, though)
@fchud Did you check ‘Status → Process’ menu to see “Core” log section? Please check if there’s an error or warning message there.
When I checked your data plan, it seems your data plan is Subscription. So I need to check that your issue is triggered by the speed cap.
My friend, I do all the steps but when I turn on the VPN to send you the packages it does not connect to any game
no error or warning messages, only [INFO].
how can we do that?
@fchud OKay… When I checked the mudfish server side, it says that you’re encountering MUDEC_00330 issue. So it seems the speed cap of your data plan affects your ping spike issue in my opinion.
i see.
tbh, i pretty much lost interest in playing this game.
i will probably try to play around with data plans on holydays, though.
thanx and sorry for all the trouble )
