Can you provide item for Call of Duty: Warzone?
Unfortunately itโs not officially supported by Mudfish yet. As workaround you should use one of methods at Unsupported Games.
And if you want to see it officially at Mudfish, please send me some game packets using Packet Capture with Mudfish link while playing the game with Full VPN mode.
I need some game packets to register new game.
updates on this? ![]()
I just uploaded a packet dump of CoD Warzone, not sure if you guys received it?
Recently Iโd created the game item Call of Duty: Warzone and added multiple game server locations. Please test when you get a chance and let me know if thereโs any problem to use with mudfish.
I did see it now. I just equipped item. Iโll test and let you know. Thank you!!!
์์กด ์์ดํ
์ ์ฌ์ฉํด์ ์๋ฒ์์น ์ผ๋ณธ ์๋ฒ ์ ์์ ํด๋ดค์ต๋๋ค.
์๋๊ธด ํ๋๋ฐ์ ํน์ ๋ถ๋ฏธ ์๋ฒ๋ ์๋๊ฑด๊ฐ์?
๊ทธ๋ฆฌ๊ณ ์ค๊ณ ์๋ฒ๋ฅผ US west ์ค ์๋์ผ๋ก ํ๋ ์ ํ๋์ด ๊ฒ์์ ํ๋๋ฐ ์๋ฌด๋๋ ์ผ๋ณธ ์๋ฒ๊ฐ ์๋๊ฒ ๊ฐ์์ต๋๋ค.
์ผ๋ณธ ์์ด๋๋ ์ผ๋ณธ์ด ์์ฑ ์ฑํ
์ด ์์ด ๋ค ์์ด ์์ด๋ฏผ ์์ค์ ํ๋ ์ด์ด๋ค๋ง ์์๋๋ฐ ์์กด์ด ํ๊ธฐ๋ฐ ๋งค์นญ์ผ๋ก ์๊ณ ์์ต๋๋ค. ์ค๊ณ ์๋ฒ๋ก ์ธํด ๊ฒ์ ์๋ฒ๊ฐ ๋ถ๋ฏธ ์ ํ๋์ด ์ง์๋ ์๋์?
I tried the Warzone item but itโs causing the game to crash as soon as it goes past the into logos
This is the only game I bought credits to use. ![]()
Edit: Deleting all the files and doing a Scan and Repair, along with deleting the players folder did the job. It works now.
However the servers are very unstable.
Thereโs a lot of packet loss. Iโm from India.
์ถฉ๋ถํ ๊ทธ๋ด ์ ์์ต๋๋ค. ํ์ฌ๋ ๋ถ๋ฏธ์ชฝ ๋ชฉ์ ์ง๊ฐ ์๋๋ฐ์, ํน์ ๊ฐ๋ฅํ์๋ค๋ฉด ๋ฏธ๊พธ๋ผ์ง๋ฅผ ์ด์ฉํ ํจํท ๋คํ ๋งํฌ๋๋ก ํ๋ฒ ํจํท ๋คํ๋ฅผ ํ์ฌ ๋ณด๋ด์ฃผ์๋ฉด ์ ๊ฐ ์ฒ๋ฆฌํด ๋๋ฆด ์ ์์ ๋ฏ ํฉ๋๋ค.
Good to hear that it works now. Did you try to change a mudfish node based on FAQ - Nodes section for your game item? If youโre using the advanced mode, please start with the basic mode.
๋ต๋ณ ๊ฐ์ฌ ๋๋ฆฝ๋๋ค. ์์ฒญํด ์ฃผ์ ๋๋ก ํจํท ๋คํ๋ฅผ ์
๋ก๋ ํ์์ต๋๋ค.
์์กด์ fullVPN ๋ชจ๋๋ก ์คํํ๊ณ ์ค๊ณ์๋ฒ๋ฅผ US West๋ก ์ก๊ณ ์งํํ์์ต๋๋ค.
๊ฒํ ํ์
์ ๋ถ๋ฏธ ๋ชฉ์ ์ง๊ฐ ์ถ๊ฐ๋ ์ ์๋์ง ๊ฒํ ๋ถํ ๋๋ ค์.
The issue has not been resolved. There is almost always packet loss and very high ping, no matter what node I try.
I even raised a private support ticket with all the details four days ago, and no one has even bothered to respond to it. I thought this was a paid service, which includes customer support, at least in like three or four days, but no response from anyone yet.
@TheXGX Iโd leaved my answer at private topic you created. Please check first. ![]()
I received it, thank you so much!
Iโm having packet loss as well. I was able to play few games with no problem but most of the times I am experiencing packet loss. Could you please help me out too? Iโve submitted ticket, but no response was received.
I have decent latency but my packet loss is too high. It stays at 70% early on then drops at the end of the game.
@desiassassin1 When I checked your configuration, it seems youโre using TCP protocol for Connection Protocols. If I know CoD: Warzone is UDP based, so I donโt think TCP works well for you.
However even if your packet loss is even same with UDP protocol for Connection Protocol, please try to:
- Changes your MTU value being more lower which found at โSetup -> Programโ
- Or try to change a mudfish node to another one based on FAQ - Nodes
Hey! It actually works now by changing it to TCP. It didnโt work with UDP enabled for me. Itโs now stable and working properly. Thanks!
It does seem CoD:Warzone is UDP based, but for some weird reason when I change my connection protocol to TCP, Iโm not getting any packet bursts anymore. To anyone looking for a fix for Warzone cause of packet bursts, change your connection protocol to TCP and it should work.
EDIT: Nope, on some games, I still have packet bursts. So I changed it back to default settings again. If any of you have a solution for this that would be awesome.
