Can anyone help verify iptime t5004
Hi, need help if someone can verify if iptime t5004 is supported by mudfish.
It seems to have openwrt support.
Thanks.
If it’s ipTIME T5004 router, you don’t need to install OpenWRT firmware because Mudfish should be supported officially. If not please let me know.
Update.
I bought one and it works!!!
Mudfish is supported and it appears in the gaming vpn settings.
