i am trying to use claude code with some other model
but those are not available in my country
is it possible to use mudfish on powershell?
Hello,Thank you for reaching out to us. To get started, could you please confirm whether How to check the basic functionality is working correctly in your environment? This is the first step we recommend. If you encounter any issues, please let us know, and we’ll be more than happy to assist you further.
If the above step works fine on your machine, it means it could apply to the powershell too because Mudfish is working based on the routing table.
yes , it works when full vpn
but i don’t want other application through the vpn ![]()
and one more thing to ask
cause claude seems blocking hard unavailable country usage
can i secure the vpn use for this ? that mean i dont want to access without vpn when some unexpected accident happen , like me forget to open vpn to access
At this moment, Mudfish doesn’t have a item for Claude Code as you might know. So I’d like to recommend Create Custom Item link.
