I normally playing Aion with mudfish many years ago and was stop. Now I trying to replaying Aion again but unfortunately, cannot open Aion Laucher when using mudfish. I can only open Aion Launcher when I don’t use Mudfish. Are there any way to solve this thing, please? Thanks.
Once you’ve logged into the launcher, you can start Mudfish, and then press play on the launcher. It still works, just got to use Mudfish connection after you’ve already signed in, but before you start actually playing the game.
The reason you could just launch Mudfish and go years ago is that the login was a part of the game client, as to now, where it’s a separate item
Really?? Thanks a lot. I will test it again like this.
Yes. I already tried both option with full vpn enabled and not enable. But still not working. With full vpn enabled.
It is working. Thanks so much for your help, bro. Now my in-game ping is improved a lot.
