Would you like to download the latest version(5.2.7) of Mudfish VPN and try again?
https://mudfish.net/download
the latest version of Mudfish is totally trash. after using the 5.2.7, I can even connect with my game…
and after using mudfish on playing Albion. I always can’t assign with the requested address
If you are using Mudfish for macOS, you must make sure that the two extensions are set up properly.
For the two extension functions, please refer to this link and check if both are allowed.
