The only way I fix this is by reinstalling mudfish but whenever I restart my PC, the problem will come back again. The solutions given like removing the adapter and reinstalling or installing OpenVPN do not work. Any help?
Edit Should I include my setupapi.dev.log?
I don’t think setupapi.dev.log includes sensitive information about your desktop but if you mind, please send it to support@loxch.com email and notify me about it.
alright, for now it hasn’t been happening but if it every comes up again, I’ll send the log to your email asap.
Okay the problem came up again so I’m emailing you my setupapi.dev.log at support@loxch.com
Thank you for sharing your file. However something is weird for me because the last timestamp to install tap0901 on your box was 2020/05/11 12:34:54.912.
>>> [Device Install (UpdateDriverForPlugAndPlayDevices) - tap0901]
>>> Section start 2020/05/11 12:34:54.912
cmd: "D:\Mudfish Cloud VPN\devcon.exe" update "D:\Mudfish Cloud VPN\OemWin2k.inf" tap0901
ndv: INF path: D:\Mudfish Cloud VPN\OemWin2k.inf
ndv: Install flags: 0x00000001
So it means you didn’t try to install the driver since that time. Is it correct?
I’m not really sure what you mean. I did reinstall mudfish whenever I have this problem though. I’m pretty sure I reinstalled mudfish again after 2020/05/11 to fix the problem.
Not sure why but IIRC there’s no logs to install tap0901 driver which used by Mudfish.
Might be it didn’t try to install it though no idea why.
If you have a spare PC / desktop, I recommend to install and test because it looks your Windows registry are something broken.
