Can't play Crazy Arcade after connecting to KR node?
Full VPN mode is enabled.
I tried changing the nodes but still get the ??? error
@triphanm1812 Are you meaning that it’s even same with Full VPN mode enabled? If then it means a mudfish node you used is already blocked by the game publisher… :frowning: You might need to test with other mudfish KR nodes.
Okay thank you.
