i can play for cabal always connection loading 46% for normal mode for Full VPN 96%
Please confirm that How to check the basic functionality works fine in your environment. It’s the first thing you should test.
When this issue happened, did you check ‘Status → Process’ menu to see “Core” log section? Please check if there’s an error or warning message there.
