Core Process Failed to authenticate using ID/PWD
I’m pretty sure I used the correct user ID and password to login to mudfish client - because I was able to use the same ID and password to log in to online account.
However, core process gave the following error.
[STDOUT]
[0.005510] [INFO] mudfish v5.2.4 (for x86_64)
[0.006510] [INFO] Timestamp: Thu Oct 1 22:41:17 2020
[0.006510] [INFO] Connection protocol: udp_p10008
[0.007511] [INFO] Authenticating… [0.178061] [ERROR] Authentication with username ‘cfeilee’ failed. [0.179062] [ERROR] Reason: Wrong username/password
[0.179062] [ERROR] [ MUDEC_00319 ]: Failed to authenticate using ID/PWD.
[STDERR]
Empty file.
:frowning: Weird… If it’s still same, could you please try to change your password to simple pattern and test? Sometimes it could happen due to special characters in the password but let’s see because I thought I’d fixed all of them…
Sorry for this inconvenience.
This topic was automatically closed after 21 days. New replies are no longer allowed.
