Hi All
I just purchased Mudfish for playing Counter Strike Global Offensive. I’m from India. My regular ping is 55-80ms. However, even with Mudfish running, there’s hardly any change in my ping. My settings are:
Destination Server : South Asia (India)
Nodes: Basic (Auto-Selection)
Thanks in advance!
It shows working fine that way. However, even in FULL VPN Model there’s no reduction in Ping.
Check ping or traceroute to Steam/Valve Official Matchmaking Server IP with/without FULL VPN
http://media.steampowered.com/apps/sdr/network_config.json
India is bom(mumbai)?
I’m sorry but could you explain how to check ping to official servers?
Yes, the Node I have selected is Mumbai (Lowest RTT).
in chrome, ctrl+f and type bom or maa.
and ping or tracert relay server address in json file
"bom": {
"desc": "Mumbai",
"geo": [ 72.49, 18.58 ],
"relay_addresses": [
"155.133.233.98:27015-27052",
"155.133.233.99:27015-27060"
"relays": [
"ipv4": "155.133.233.98",
"port_range": [ 27015, 27052 ]
"ipv4": "155.133.233.99",
"port_range": [ 27015, 27060 ]
"service_address_ranges": [
"155.133.233.0/24"
In CMD, I used “ping 155.133.233.99” and other ipv4 addresses.
The Ping then was around 65ms. (Without Mudfish)
On Full VPN mode it is around 40ms.
Hey
Is there any way to get this working without Full VPN Mode?
Weird… When I checked the game item of CS:GO it seems 155.133.233.99 and other game servers should be applied by the game item of mudfish. So I guess that your setting should show 40+ ms without Full VPN mode.
Please check it first after turning off Full VPN mode. If it doesn’t work without Full VPN mode, please send us some game packets; Packet Capture with Mudfish
