Currently playing Blade and Soul, but when i have mudfish open the fps locks at around 30 fps. I have tried to load the game with mudfish closed and i have a normal 120 fps. This issue only happened today
fast connect mode does not work as when it is turned on it does not work. I have tried UDP before but the performance is poor. With TCP i get 250ms in game, UDP is about 400 which is the same as when i dont have mudfish running.
issue is continuing to occur today
today i have loaded it in both TCP and UDP, with fast connect both on and off. I am still being capped at 40 fps
i am having to forgo using mudfish in order to be able to play at a decent frame rate.
Please let me know if there is a fix
Issue is continuing, but doesnt occur all the time. Is there anything i can do?
Today i have tried it in full VPN mode but i have the same issue
